Case sealant
Thread: Case sealant
    Sep 2017
    Newyork
    Case sealant
    Totally forgot to order some when i placed order with SBT. What can i get from local auto parts store that will work? I have Autozone, parts plus and advance auto local to me.
    Re: Case sealant
    Motoseal 1 Ultimate.
    PWCToday.com Is My Home Away From Home kcr357's Avatar
    Sep 2008
    The flakka capitol of Florida
    Re: Case sealant
    I like loctite 518
    How many gerbils could a gerbil jammer jam if a gerbil jammer could jam gerbils?
    "You build cheater motor's & still get smoked !!!!"
    "Its not your fault. You just don't understand what you're talking about. "
    Sep 2017
    Newyork
    Re: Case sealant
    What do you guys suggest to use on all case bolts?
    Re: Case sealant
    A dab of blue Loctite every nut or bolt.
    Top Dog Benflynn's Avatar
    Birmingham
    Re: Case sealant
    Go to yamaha dealer and get yamabond4
    Aug 2008
    Indianapolis
    Re: Case sealant
    Quote Originally Posted by kcr357 View Post
    I like loctite 518
    NO! This is the most horrible crap there is. The ONLY case sealant you should be using is a thin silicone-based sealant. I use Threebond 1211. (Threebond also makes similar versions , like the recommended Yamabond 4, but this version dries quicker than the 1211)
    Rotax must have had some brain-dead engineers when they specified Loctite 518 back in the day. They finally wised up and went to a silicone sealant for cases in 2001. One of the best reasons to ONLY use silicone these days is because you never know the history of an engine you are working on. If it ever has used silicone, then Loctite 518 will NEVER set properly on those case halves again.
    A lot of "leaky inner seals" are misdiagnosed. What is happening is the 518 breaks down and the oil is leaking at the case halves.
    Top Dog TMali's Avatar
    Mar 2011
    Brooklyn Center, MN
    Re: Case sealant
    Yamaha bond 4
    and
    Blue loctit on all bolts thoughout the ski
