1997 seadoo xp
Thread: 1997 seadoo xp
    Oct 2008
    Richland Center WI
    1997 seadoo xp
    Hi, looking at buying a '97 xp.
    Probably look at this weekend, all go well coming home with. Have a few ??
    Will check compression an water test an
    Replace gray fuel lines, carbs rebuild, pump oil.
    Fuel gauge doesn't work, any thing to check specifically with the 800 engine or the ski?
    What should compression be?
    Got him to $1200.. no trailer just ski.
    Any thoughts, price to high?
    Jun 2011
    Re: 1997 seadoo xp
    Good price, only use genuine Mikuni parts and also be sure to change the Needle/Seats with genuine Mikuni, pressure test the carbs for gasket leakage and check that the bypass holes are clear of debris, change out the fuel selector and water separator bowl o-ring, be sure to pressure test the jet pump after re-assembly for leaks, check end threads on the impeller shaft for wear as well as measuring the run out on it where the bearings contact it, fuel gauge doesnít work because the fuel gauge float might be saturated with fuel, compression should be about 150 psi, check for excessive smoke and a high idle (3,000rpm on the trailer & 1,500 rpm in the water) upon start up, check the wear ring, pump vanes and impeller condition, check for any water leaks coming from any of the 4 exhaust pipe welsh plugs(casting plugs welded onto the pipe) & carbon ring condition as well as the rubber bellow with the 2 worm clamps from the carbon ring that is on the driveshaft & the 787 Motor is a solid performer!
    What would Chuck Norris do?
    Oct 2008
    Richland Center WI
    Re: 1997 seadoo xp
    Alright, thanks. Will check it over good!!
    What should be the lowest allowed compression.. 140?
    Anything to check on the rave valves.. no experience with em. Just rotary valve on 657..
    Jun 2011
    Re: 1997 seadoo xp
    The RAVES can be checked by pushing in on the top of it w/o removing anything and should move up & down freely w/o sticking or hanging up. If removing the RAVES. They probably will need the carbon build up removed even if they move freely. If they have been upgraded. They will have a line/slot cut into the left and right side of the valve.
    Lowest compression Iím comfy with on a 787 Motor is 135 psi with a difference of 3 psi between each cylinder and a minimum of 3 compression tests with a cold engine and the throttle pinned wide open.
    PWCToday Newbie KevinLamb's Avatar
    Jan 2015
    SoCal
    Re: 1997 seadoo xp
    Cliff writes: If they have been upgraded. They will have a line/slot cut into the left and right side of the valve.
    Cleaned the RAVES on my pre-owned 97XP. The Raves are slotted. Are you saying the ski did not come with these grooved paddles when it shipped new from the Factory? Why did the slot option come to exist? Melting bellows?
    PWCToday Guru 1983's Avatar
    Jul 2014
    North Carolina
    Re: 1997 seadoo xp
    There was a tsb from seadoo in 1997 for hesitation. I will try and attach a link to it:
    Click here, it should download the .pdf: SeaDoo 1997 RAVE Hesitation TSB.pdf
    Quote Originally Posted by KevinLamb View Post
    Jan 2015
    SoCal
    Re: 1997 seadoo xp
    Quote Originally Posted by 1983 View Post
    Great - that clears it up - the 97XP left the factorty with the fix, some of the other models did not.
    Thanks.
