1995 Yamaha FX1 TRUE B PIPE- Michigan
    Resident Guru eat wake's Avatar
    Jul 2007
    Portland, MI
    Putting out a feeler to see if there is any interest in my FX1. I have not been able to use the jet ski but one time in the last three seasons. I have honestly don't nothing except replace a steering cable on this ski since 2012. It has been a great machine to me and I believe it will continue to be a great machine to its next owner. One of the last times the ski was in the water, a tubby completely ripped off, so it will need some cosmetic attention (or new tubbies) below the rail. The ski has been stored indoors since I have owned it, but the paint has faded slightly over time. It currently houses a true fx1 factory b pipe. There is a lot of custom work done to the ski, and its one of a kind on the water. I have a clean title ready to go.
    HULL
    carbon reinforced hull with foot holds and scupper drain
    144mm pump conversion
    the hood was hollowed out to make it lighter
    hooker 9/15 impellor
    Kart tank (stock included as well)
    blowison pole bracket
    x metal alum pole
    blowsion pole spring
    carbon chin pad
    blowsion finger throttle
    pro-tec scoop grate
    MOTOR
    61x stock (145/145 psi readings; Id assume # goes up w regular use)
    carbon fiber reeds
    pro k f/a
    44 carb, and k+n f/a (cant remember if intake is stock or not)
    Asking $3,200. I would also consider parting it out (from bare hull/hood to motor ready)BUT THE HULL NEEDS TO BE SOLD AND PICKED UP BEFORE ANYTHING ELSE GOES.
    Prefer local sales.
    1982 Kawasaki 550- original
    Jul 2007
    Portland, MI
    Re: 1995 Yamaha FX1 TRUE B PIPE- Michigan
    Ttt
    Nov 2015
    ontario
    Will you part out the b pipe ?
    Jul 2007
    Portland, MI
    ttt
    Oct 2013
    funky town
    In the third picture, there is some grass growing through the expansion joint of the driveway. Are you willing to trim it and sell? I would need it shipped.
    I'm only here to make you mad
    Jul 2007
    Portland, MI
    Grass is dead, Id feel bad selling it to you.
    $3000 is the new price for ski...
    Jul 2007
    Portland, MI
    Sold
