Results 11 to 20 of 21
    Oct 2017
    Mesa, AZ
    Re: JS550 Newbee, won't start
    Good starter,good battery, tried WOT, plugs are NOT wet. Dead crank-no sputter at all. Going to pull carb and intake tomorrow, see if there is anything screwed up there. I do appreciate everyone's input. Someday we will figure this thing out !!!!
    Aug 2017
    FL
    sounds like a fuel issue
    Oct 2016
    Columbia SC
    BN carb? I had similar sounding problem after rebuilding the BN. A new SBN from watcon fixed that.
    Is the engine grounded to ebox? Just asking.
    Have you considered putting a 650 engine in it?
    Parting out what you have might even cover costs.
    If I knew then what I do now, I would not have rebuilt my 550pp engine.
    Dec 2009
    Buffalo
    If you rebuilt your carb and it ran before but now it doesn't, that's probably the issue then....
    Oct 2017
    Mesa, AZ
    It is a BN carb, no it didn't run before carb rebuild- thought that would take fix it. Engine is grounded to ebox.
    Oct 2016
    Columbia SC
    Seems strange that fuel down the carb did not work. What about the timing position?
    This stand up jetski lark gets better.... apparently.
    Have you located anyone local that can put a carb that works on to isolate the issue?
    My BN was pulling fuel and pumping back to tank, something was blocked inside.
    But the time I removed and reinstalled three time to check, I had assembled correctly and tried to blow any debris through. I was done. SBN time.. expect about $300 for carb, spacer, x4 manifold gasket, x2carb gasket, extra fuel and pulse line hose, and you need longer bolts to connect manifold with the spacer.
    PWCToday Newbie skidooseadoo's Avatar
    Jun 2016
    Ontario
    Flywheel woodruff key timing may be off.
    Oct 2017
    Mesa, AZ
    No one local has offered a carb to try, wish they would. I will ck the timing on Monday, off to the Dunes to run our quads this wknd. Again, thanks for all the input, I truly appreciate it.
    Feb 2016
    New Zealand
    Quote Originally Posted by jby257 View Post
    I was thinking the same. My old JS440 fired in the bench without a carb attached. Just used a spray bottle with premix down the inlet. Not ideal and obviously didn't run but got a pop and a bit of smoke. Sounds to me like timing or weak spark.
    They are a pretty basic engine. Just need a gob full of gas and spark at the right time and something should happen.
    Oct 2017
    Mesa, AZ
    Upon further examination here's what I have discovered. Head gasket on wrong, different thickness intake gaskets, no shims in motor plate so coupler is not aligned or spaced correctly, impeller rubs. The whole motor is suspect therefore I am going to tear it down replace crank seals, fix all the above and see where I'm at at that point. I'll get bk to you when all is completed, and hopefully running. I know carb is still suspect.
