Vx cruiser has high idle??
    Oct 2017
    Greece
    My yamaha vx cruiser has a high idle once you start goes up and down ,once you blip the throttle it goes back down but straight back up again ??i have cleaned the throttle body all looks clean and ski runs fine.Please help me
    Re: Vx cruiser has high idle??
    Could be the TPS sensor is bad. May have to have it scanned / checked for codes.
    email watcon@watcon.com
    Please visit our web sites
    Oct 2017
    Greece
    hi thanks for that no codes showing up or is there a way i can check for codes?
    Aug 2010
    Australia
    you have a fuel pressure regulator issue , try clamping the return line, or you could get a new TPS LMFAO!
    modded X2 650
    900 powered custom 650 sx .
    Jul 2018
    VA
    What did the problem turn out to be? I am having the exact same problem
    [QUOTE=samosjetski;4453346]My yamaha vx cruiser has a high idle once you start goes up and down ,once you blip the throttle it goes back down but straight back up again ??i have cleaned the throttle body all looks clean and ski runs fine.Please help me[/QUO
