2013 GTI 130 Gauges
    PWCToday Regular goingpwc's Avatar
    Dec 2009
    Utah
    2013 GTI 130 Gauges
    Can anyone instruct me as to how I can access the gauge cluster and replace the wear rings on the steering column of a 2013 GTI 130.
    Dec 2009
    Utah
    Re: 2013 GTI 130 Gauges
    I was able to figure out how to get to the wear rings. It is a delicate process to remove the bezel covering the gauges which also allows access to the steering shaft where the wear rings can be accessed. One of the wear rings was broken and the other was worn badly which created all the movement in the shaft. The wear rings are replaceable and available from seadoo, $10.50 each.
    PWCToday Regular xspook's Avatar
    Nov 2008
    florida
    Quote Originally Posted by goingpwc View Post
    What do you mean "access" the gauge cluster? You want to remove it?
    The procedures to remove the gauge cluster for a 2011: (should be same for 2013)
    1. Open front storage compartment cover (hood)
    2. From underneath the two mirrors, remove the screws from the bottom.
    3. Use the palm of your hand to "bump" the front part of the mirror toward the rear to release the trim.
    4. Press in on the two retaining tabs on the top of the gauge
    5. Tilt forward and remove gauge
    Now: 2011 SeaDoo GTI SE 130
    Then: 2008 SeaDoo GTI SE 130, 1994 Kawasaki SS Xi, 1989 Kawasaki ZX10, 1986 Yamaha Radian
