    Dec 2014
    SRQ FL
    Throttle cable question - 750 twin carb swapped into 650sx
    My 650sx throttle cable is not long enough on the push/pull throttle bracket for the twin keihins from the 750SS and I tossed the 750ss hull and throttle cable. I'm using the 750 throttle cable bracket (the one that's attached to the block) but the ferrule end of my cable is just barely too short. Anyone have any input or suggestions? Thanks
    1992 Kawasaki SP 750sx - Big pin cyl, 1 mil overbore, Triton Engineering head, V-Force Carbon v3 reeds, Coffman Signature series pipe and silencer / WB bypass, dual SBN44 on R&D dual singles, HotProducts F/A, AC Racing v2 alum pole, Jetworks bars, full Jettrim, OP rideplate, Westcoast scoop grate
    May 2011
    miami
    Re: Throttle cable question - 750 twin carb swapped into 650sx
    Drill new holes on the bracket and move the bracket towards the carbs if you have space or get a sxi bracket. It has more material to work with.
    May 2011
    miami
    750ss left. 750 sxi on right
    Dec 2014
    SRQ FL
    Damn, that might be the solution right there. Thanks man
