Gas Leak can't figure out how
    Aug 2017
    canada
    Ok, first off, I'm a total noob when it comes to this stuff, so I apologize on that front.
    Background: I bought a 96 seadoo SPI this past summer to run at the lake and tow the kids around on. I had an issue when I first got it in that when I had the gas knob to "on" it would not take any gas in. The repair shop said they couldn't fix it because they didn't have the parts in stock so it'd take a while, and that if I just used the reserve setting it'd work. Which it did. I was fine with that.
    When I took it out of the water this fall, I had it parked in the driveway for a bit before cleaning it up and winterizing it. I noticed that it was dripping gas ever so slightly on the left side of the hull (that's the left if i'm sitting on the sea-doo!). I am 99% sure i never had this leak when it was in the water, because I never saw any gas/oil slick in the water, never smelt it, etc...Anyways, I can't figure out how it's leaking and would prefer to figure that out before winterizing (all winterizing blogs I read indicate to put a full tank of gas into it for winter, with stabilizer).
    In terms of the leak, when I poke my head in and have a look, there appears to be a gas line (yes, I'm still using the old grey ones) that runs from tank and to the inside edge of the hull. You can see from the pictures on the inside, here is the gas line going to the edge of the hull.
    This next picture shows the outside of the hull. There's some sort of black fitting just under the "ridge" where the top of the machine meets the bottom. It seems to be leaking out of there.
    I have no idea why there is a line that goes to the edge like that. Any info/advice is greatly appreciated. I was going to winterize this all myself, but figured since this leak, I better get it addressed first!
    Any info/advice is greatly appreciated. Cheers from the East Coast of Canada!
    Feb 2002
    Vancouver, BC Canada
    Re: Gas Leak can't figure out how
    It appears the on fuel line and the vent line are switched on the fuel baffle. Switch them back. Also, check with your dealer for a gas tank recall.
    Where do you live?
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    Aug 2017
    canada
    Thanks for the reply. I'm in new Brunswick!
    It seems to leak at this point no matter where I have the fuel switch turned to (on, off or reserve). Like I said, it didn't appear to leak in the water.
    Maybe during transport (when it was in the Off position) some got into the vent line and now it's just leaking out. Not really sure...
    cheers
    Feb 2002
    I already explained the problem and the solution. Never mind the fuel switch. Did you check the fuel lines on the baffle? They have been switched, switch them back. If fuel is leaking from the vent line, that means it has been connected to the on nipple on the fuel sender (baffle) and is getting fuel from the bottom of the tank. The on hose is sucking air from the top of the tank.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
