Results 1 to 2 of 2
    Sep 2017
    Indiana
    pressure or vacuum leak down test?
    So is there a preferred way to do a leak down test? If you put 10lbs of positive pressure in an engine then you have the opportunity to confirm where the leak(s) is coming from with soapy water. Most of what I see however uses a vacuum.
    Frequent Poster a1cnc's Avatar
    Jun 2017
    NH
    Re: pressure or vacuum leak down test?
    I would say the pressure test is more effective for being able to visually find leaks but it is worth performing both as the crankcase will see negative also.
    1998 ZXI 1100 Red
    2001 SeaDoo GTS Sold
    1998 ZXI 1100 yellow ...coming soon
    1994 Polaris SL750 $50 I couldn't help myself!
    I suffer from JOCD!
    Jet-ski Obsessive compulsive disorder
