2000 RX Millenium Edtiton starting issue
Results 1 to 9 of 9
    Aug 2015
    Tarentum, pa
    I recently bought this ski, 2000 RX Millenium carb'd 951. It was advertised as not running, so when I went to see it I did a compression test and checked for spark. Both were good so I bought it. I think I got a fairly good deal at $650 including an aluminum triton single trailer.
    I got it home and changed the fuel and plugs and it started and I ran it for about 10 seconds but it wouldn't rev well. The next time I tried to start it a few days later, it would start after a little cranking but would only idle for a few seconds and then die. I'm sure the carbs need rebuilt and lines need replaced, but here comes the real issue. Each time you attach the key you get the normal 2 beeps. After a few cranking attempts the starter will continue to crank after you let off the button, and even after you yank the dess lanyard. you have to disconnect the battery to make it stop.
    I have replaced the starter solenoid, which did not correct this problem. Could this starter issue be a dess or mepem problem? I'm aware I'll have to go through the carbs, lines, rave valves, etc to get it running well but I don't know if I want to spend the money on a new mpem, plus all the usual carb,lines etc. Is this ski really worth sinking that kind of money into? The motor is supposedly fresh and a compression test verifies this at 130 psi per cyl, but the ski itself has like 650hrs on it
    Sep 2008
    The flakka capitol of Florida
    Re: 2000 RX Millenium Edtiton starting issue
    HOLY****!
    650 hours?!?!
    That's gotta be a record for a 951.....
    If it's in good shape, why not fix it? The RX is the best 2 seater stroke seadoo made.
    First thing is attach a voltmeter to the wire that switches on the solenoid. Try starting it, then see if there's voltage once you let off the start button.
    Aug 2015
    Tarentum, pa
    Good point, that'll tell me if the switch is still trying to close the solenoid, possibly sticking start button?
    Sep 2008
    Maybe. If you go to the top of the seadoo tech section, there's a sticky with the shop manuals that have a wiring diagram.
    Aug 2015
    Tarentum, pa
    So i just tried something real quick. Lanyard off, hooked up batt and it starts cranking away, pulled the fuse on the red wire near the solenoid, still cranking. Unhook battery, tap on new solenoid, rehook battery and acts normal. Try to start and it backfires real loud
    Sep 2008
    Weird. Btw it shouldnt crank with no lanyard. Did someone do some "mods" to the ignition?
    Aug 2015
    Tarentum, pa
    Not that i can tell
    Sep 2008
    It def should not crank without the lanyard. Starting to think the mpem is bad
    Aug 2015
    Tarentum, pa
    I also noticed the guages did not power up when i attached the key. But the battery may be slightly low from cranking
