Results 1 to 8 of 8
    Sep 2017
    Indiana
    waterbox sealing
    I haven't found a thread on how to seal a stock 550 waterbox. I bought a used one to replace the loud aluminum one in my ski and when I fired it up I noticed smoke coming from the front of the ski.
    What's the best way to seal it and with what?
    Mar 2011
    Brooklyn Center, MN
    Re: waterbox sealing
    Get a new one. That one is junk and ready to split open.
    If your really set on keeping that one, i would fiberglass the whole thing
    OR
    Are you sure its the box? not a bad hose or bad clamp now?
    Dec 2009
    Buffalo
    I used 3M 5200 to re-seal my 550 waterbox years ago. Have to use the stuff that cures over 7 days, split it in the 2 halves, clean it, re-seal
    Top Dog
    Oct 2006
    under a ton of work
    used to use the grey marine tex to glue both halves after mods..
    op,i have a clean used box if yours is beyond repair.
    Sep 2017
    Indiana
    I just got this ski. It had a Westcoast waterbox and although I really do like the way it sounds it's just LOUD! I bought a stock one on here but when I put it in and fired the ski up I noticed wifts of smoke coming from the direction of the waterbox. I think I'll try the 5200/marine tex approach on everything that looks like a seam and try it again. For ****s and giggles I put the Westcoast back in and didn't see the smoke so I doubt it was a hose clamp or the like.
    I appreciate the help fellas!
    Frequent Poster heresjohnny151's Avatar
    May 2008
    brea, california
    I know this response is a little late to your post, but you can try diverting more water into the exhaust to make it a little less noisy. (still using the westcoast water box) If you choose to repair the stock water box, i have always had good results using fiberglass resin with chopped up fiberglass.
    Sep 2017
    Indiana
    Actually, it's still warm enough to ride here and I had a few other issues to work through before I put it on the stand and start working my winter tear down. I put the westcoast back in to avoid the exhaust under the hood. How do I divert water into the westcoast and how much will it muffle? My goal is to annoy as few people as possible.
    May 2008
    brea, california
    Sorry for the late reply...you can t-off from the front of the head into the tail end of the exhaust pipe.
