    Aug 2017
    North Dakota
    Repitched SXR prop vs Hooker?
    I have a stock big swill sxr prop that I can get repitched by impros to 9/17. It's be balanced and trued for 150 bucks. Is that the way to go vs getting a Hooker 9/17 big swirl from Impros? Its a slightly modded 650ski for rec and freestyle use on lakes only. So low end is what im after.
    Aug 2007
    Re: Repitched SXR prop vs Hooker?
    Why don't you just ask Dave at Impros?
    Jun 2011
    Napa
    the SXR prop will be heavier.
    will it be cutback for the 650 pump as well?
    - John Kenneth Galbraith
    Aug 2017
    North Dakota
    Mr. Dave Stewart did recommend the impros prop. Thought I'd ask X2 guys that might have some added insight
    Jun 2011
    Napa
    I have ran both cutback sxr and hooker.
    Never back to back, I have bought 3 or 4 hookers, i don't see anything wrong with them.
    Only 2 modded sxr props
