Scored a sxr... Needs some engine advice, 750 engine the same? - Page 4
Results 31 to 38 of 38
  1. #31
    Aug 2017
    Vancouver Island, Canada
    Re: Scored a sxr... Needs some engine advice, 750 engine the same?
    I bet that I have 10 of those in my gasket stash, how many would you like?
    This one BLRider
  2. #32
    Aug 2017
    So I've got it all together and fired it up and it's idling really high, it's not a runaway bit feels like its going to. I've backed of the idle screw completely. I've also done a leak down test and it holds 10psi for 10 mins. Seeing as the carb is from a 800 and I put a 750 small pin in there, is this just a tuning issue? When I apply the choke it kills it so I think I'm rich? I've turned the low speed screws in a bit. Which direction should I go if it is carbs? Tighter or looser?? Anything else I should check?
    I know my way around skis pretty good, carb tuning, not so much
  3. #33
    Feb 2002
    Vancouver, BC Canada
    If you backed off the idle screw, the throttle cable is too tight. Something is holding the throttle open a little.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
  4. #34
    Aug 2017
    Chester
    I'll check that, thanks Chester! Seeing as it's a 750 small pin with sxr 800 carbs with stock settings do you think I'll need to rejet? just minor adjustments? or leave them be? As you know it's a little too chilly to head to the lake to tune it here in BC.
    Thank you!
  5. #35
    Feb 2002
    Too chilly for some. I was out riding last week to test ride a customer's Jet-Ski.
    Do you live on the coast? Put where you are from in your location, Canada is big.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
  6. #36
    Apr 2006
    Oregon
    Check the throttle cable like Chester says. If that's not it, verify that the throttle plates are not worn on the sides at the throttle shaft or that the throttle shaft bushings are not roached. Also verify that there is not an intake gasket or carb base gasket leak.
    Also, turning needles out (CCW) is rich, turning in is lean.
    Home of Newmiller Machine
  7. #37
    Aug 2017
    Chester
    I'm over on the Island, from Vancouver originally. When I first started riding I would put on the 6mm stiched and sealed suit with gloves, boots, and hood and rip it up year round. Now I stick with dirtbiking when its cold, hard to get motivated to put on the suit and get wet....getting old and lame I guess, lol
  8. #38
    Aug 2017
    thanks guys, I feel like such a rookie.... I pressure tested both the carb and the engine, checked pop off, replace needles and seats, etc.....and I forget to adjust the cable, that's what it was! LMAO!! It's responding very good now so I guess it's time to suit up and head to the lake for fine tuning.
    I appreciate the help..........Rookie out!!lol
