Results 21 to 30 of 38
    Aug 2017
    Vancouver Island, Canada
    Re: Scored a sxr... Needs some engine advice, 750 engine the same?
    anyone....am I all good? Thanks
    SE MI
    All good. Pickup location is the same.
    Aug 2017
    On to the next issue. So I replaced the needles and seats but one of the carbs is puking gas into the engine from the inner venturi. IMG_20171110_141319381.jpgIMG_20171110_141319381.jpg
    In the pic, the totally clean plug is from the side with all the gas coming in, and the one that looks fouled is from the other side. Both have good spark.
    I just replaced needles and seats, black springs, full clean and the rest looked good in the carbs. From what I've read it could be a leeking needle, or the needle getting hung up, is there anything else that would cause all this fuel to be dumping into the engine from the inner venturi at idle? (that's the high speed jet right?)
    Thanks in advance
    Resident Guru ang4th's Avatar
    Aug 2003
    Hamilton,ontario
    hey I am in Canada I have some sx and sxr parts need a intake toploder ? also a 750 smallpin bottom end I think crank is useable if your interested .. see my ad other posts
    "It is better to keep your mouth shut and appear stupid than to open it and remove all doubt."
    Hamilton Ontario Canada . need old school Kawasaki 650 , 750 or some basic superjet parts and you are within Canada ? message me I may have parts available
    Aug 2017
    Fixed, it was the spring arm for popoff, it was bent way up therefor the diaphragm was holding it open...... Still have to tune it but it's way better now..... Woohoo, progress... Lol
    Aug 2017
    I'm looking to order a gasket kit, some sellers in the states charge a ridiculous amount to ship here. I found a gasket kit for an 2000 sxi pro. I assume the head gasket is different but are the rest of the gaskets the same?
    SE MI
    Quote Originally Posted by Yabadabadoo View Post
    Check out this thread, it may have the gaskets you're looking for
    http://www.pwctoday.com/showthread.p...596&highlight=
    Aug 2017
    Thanks..... It's the Muffler gasket that's leaking round 3 hole with water jacket slots. Most top end kits don't even come with them. all exhaust gaskets are the same for the 750s and 800s right?
  9. #29
    SE MI
    I bet that I have 10 of those in my gasket stash, how many would you like?
  10. #30
    Aug 2017
    Thanks BLRider. I just ordered a full kit. I figure I might as well do the crank seals over winter.. Appreciate the offer though.
