Results 1 to 2 of 2
    Sep 2016
    Redding
    Need help with orientation of thru hull seal
    Lost my thru hull seal a few weeks ago. When I pulled the drive shaft the balls all came out in a rusted heap. Had a lot of trouble pressing the seals and bearing out. Which resulted in a somewhat indistinguishable mess.
    I was hoping someone could point me in the right direction. Do the seals all open inwards or do they face each other? ( i.e do I need to flip the two innermost ones to open towards the outer?
    I have them laid out the way I was planning to install from left to right
    Also, a little white lithium grease on the install?
    Jul 2012
    so- california
    Re: Need help with orientation of thru hull seal
    Quote Originally Posted by cj3waker View Post
    That is the correct order I believe
