    Mar 2005
    Mooresville
    Single 48 Novi too much for a 650?
    Would a 48mm single Novi be too much for a 650? Mods are factory pipe, and skat 6 impeller. I would change reeds to boyeseen. Just trying to figure if this would be too big for the motor. Thank you for you help.
    SE MI
    Re: Single 48 Novi too much for a 650?
    A 46 is a lot for a 650, the 48 would be great in a massaged 750.
    Mar 2005
    Mooresville
    That's was I was worried about. Would love to get one that would work both in the 650 and the 750 for when I blow the 650 up.
    Sep 2002
    gold coast
    It will work just fine, it will not blow it up at all
    Www.waxracingproducts.com
    Mar 2005
    Mooresville
    I am not worried about the carb blowing up the 650 just a generalized comment for when the 650 does give up the ghost my plan was to put a 750 in it. Wax racing do you have a suggestion on what jets to run? Thanks again for all of the help.
    Top Dog bandit88's Avatar
    Green Bay WI
    Bet you would get better performance from dual 38s than a single 48, cheaper too. That carb is too big for most 650s. The intake signal will be garbage and so will be you tuning.
    -95 750SXI
    -90 TS650
    -91 300SX
    Sep 2002
    gold coast
    No idea on the jets sorry, but i to would go for twin 38s as suggested above
