Tips for converting 650 electronics to 750 electronics
Results 1 to 8 of 8
    Aug 2017
    North Dakota
    Hi all, i got my 750 electronics, 95 750 ss (thanks skags), now am mapping out how to convert my 88 x2 to use it. There are a few extra cables and some of the connectors are different then what i know. I searched for diagrams but came up empty. I'm guessing you connect everything like normal and go from there? Just wondering if I need to do anything special i guess. Any advice would be awesome.
    Jan 2011
    winnipeg
    Re: Tips for converting 650 electronics to 750 electronics
    Odd. Most people convert 750 x2 to run 650 electronics due to lighter flywheel. Heard of it being done but not sure if it's worth it just for the different timing curve. Typically just hear running advance 650 electronics and lightened 650 flywheel. That's what I have in my 750 x2 and happy with that.
    SE MI
    I've done this swap multiple times and wI'll never go back. You already have the SS parts and the 750 flywheel and front cover will bolt right on. The electrical box will be a little more of a challenge. The start/stop switch could have different color wires but with a quick look at the two wiring diagrams will solve this minor issue.
    Worthy upgrade for anyone willing to do a little work, the 650's respond well to the 750 timing curve.
    Aug 2017
    North Dakota
    Thanks BL, that is what I've researched as well. Can you advance timing a few degrees as well with this swap or is it unneeded?
    SE MI
    There is a $50 - $60 R&D timing 7 advance that is (was) produced. Not really needed.
    Top Dog Benflynn's Avatar
    Aug 2015
    Birmingham
    No, the stator won't advance w/o adapter
    I dream skis sportsfreak29's Avatar
    Oct 2011
    Midland, Tx.
    Is it possible to run the 750 electronics with the 650 flywheel and stator?
    Ski situation in limbo!
    Special thanks to Chris Newmiller, and Mitchell at M&M Marine!
    SE MI
    No, they aren't compatible.
