Results 1 to 9 of 9
    Frequent Poster sportsjunky's Avatar
    Jan 2010
    Canada
    Question about 951cc in a HX hull
    Iam thinking about putting together a 951/1020cc with a Coffman pipe in a HX hull...
    My question is which Coffman pipe is best suited for this application, the GSXL or the XPL pipe ??
    Will both work, or is one better then the other (fitment) wise ??
    Any input is welcome
    Thanks!
    Dec 2011
    Niceville, FL
    Re: Question about 951cc in a HX hull
    I think the GSX is better but the Rossier fits the best. I have a brand new Coffman pipe I'd sell for a grand. I was told it is a RX pipe (1of 10 made) and it's in between the GSX and XPL versions.
    Jan 2010
    Canada
    Hey Matt! thanks for the input on the pipe... any chance you could post a pik of your "RX" Coffman pipe when you get a chance sometime? I would love to see it
    Jay
    Dec 2011
    Niceville, FL
    You bet. I'm happy to say I'm 4 hours away right now on a weekend river ride with a music festival cranking next door but I'll be back there Monday morning.
    Dec 2011
    Niceville, FL
    Here we go Sport thanks for the interest....
    Jun 2017
    North huntindon
    Im contemplating the same build. I have 3 hx's and I've been itching to put a 951 in one of them.
    I have a 98 xp with a fresh 951 that may get yanked. if you do this build, keep me updated. Im sure we can
    share some info along the way to help each other out.
    Are you planning on putting the bigger pump in the hx as well? That's the part of the build I'm nervous about.
    Ive been on the HX since they came out in 95 and have been wanting to do this for 20 years
    Jan 2010
    Canada
    Hey TDog ! Iam just trying to get my hands on a HX hull at the moment. But to answer your question, I would most likely go for the pump switch to a 155mm...
    If you check out "Individual Builds" on this site there are a handful of other guys that have already done this, and they give step by step info on how to do everything for the swap including the jetpump...
    Iam pretty sure ya just yank out the 140mm stock pump's "pump shoe" and you just use your 155mm pump shoe as a template and drill the hole accordingly and your off to the races....
    But when I get my build in gear I will document it for sure!!!
    Jay
    Jun 2017
    North huntindon
    Not sure if you found a hull yet but theres one in Vancouver for $250 listed in classifieds. if that's the side of Canada youre on?
    after looking at some of those other builds, Im pulling the trigger. gonna start the build in the spring
    Jan 2010
    Canada
    Oh, thanks for info on the HX hull... Iam close to Toronto, but I think I got a line on a hull... And Iam glad to hear that your motivated to do this project, hopefully that will get my butt in gear soon too.... lol Between the help from each other and others on this site and looking thro the multiple HX build threads previously done , I think we should be in good shape to pull it of
    Jay
