Results 1 to 2 of 2
    Sep 2017
    Indiana
    kerker pipe advice
    I have an 82 JS550 with a Kerker pipe. There is a bracket on the bottom of the pipe to attach it to the motor mount bolt. This bolt backs out so I'm replacing it with a new one. What are the consequences of not attaching the pipe to the motor mount?
    charlotte,nc
    Re: kerker pipe advice
    it could vibrate loose and come apart from the coupler holding it to the head pipe. 2 strokes vibrate. a lot. if the bolt is backing out might want to check your engine mount threads.
