Page 1 of 3 123 LastLast
Results 1 to 10 of 29
    Jul 2014
    edmonton, alberta
    1993 Kawasaki 750 sx Parting out
    Looking to part out my 750 Sx, everything is available from a running ski
    750 sx small pin motor( I'll check the compression when i get home)
    AC aluminum Handle Pole - Purple
    Brand new SOLAS KE-CD 9/15 - Ran it for an hour this year
    Jet Dynamics intake grate
    Stock Carb- replaced fuel pump two years ago.
    Aftermarket rideplate( cant remember the brand)
    Let me know what you need and make an offer.
    located in alberta,canada
    Jul 2014
    edmonton, alberta
    Re: 1993 Kawasaki 750 sx Parting out
    Motor is showing 152psi on back cylinder, 155psi on front cylinder.
    Exhaust & Manifold is Sold
    AC Handlepole - Available
    Ebox- Available
    Hood -Available
    Starter Switch - Avaliable
    Carbs & Intake box-Available.
    More pictures to come
    Jul 2014
    edmonton, alberta
    Ebox- Sold
    Intake Grate - Sold
    Starter Switch Sold
    Ride Plate -Sold
    Jul 2014
    edmonton, alberta
    Impeller Solas 9/16-only one hour of use-make an offer
    Sent from my XT1650 using Tapatalk
    Jul 2014
    edmonton, alberta
    Handle pole and pad-make an offer
    Motor-152&155psi
    Stock keihin carb with new pump
    Intake manifold
    Make an offer. Looking to clean out the garage
    Jul 2014
    edmonton, alberta
    Everything that's available
    Top Dog still standin's Avatar
    Jul 2009
    michigan, KZOO
    Do you have the Pole pin thing that holds the handlepole up?
    -92 550sx/750 conversion
    -94 750sx modded
    -86 X2 - Twin carb 750 swap
    Jul 2014
    edmonton, alberta
    No. The handlepole goes far enough back that it stays up on its own
    Aug 2017
    Vancouver Island, Canada
    Pm'd re engine to bc Canada
    Jul 2014
    edmonton, alberta
    Motor sold
