    I dream skis sportsfreak29's Avatar
    Oct 2011
    Midland, Tx.
    JS300, 300sx questions
    I recently purchased a complete 300sx to build a 750 conversion with the soon to be released Rhaas pump kit, and want to put the 300sx motor in one of my extra JS hulls for my kids to ride.
    There's a lot of info on the 300sx conversions, but limited info on putting a 300 motor into a 440/550.
    I need some input on what parts I'll need for the motor mounts and running the exhaust.
    Thanks, J
    '84 js550/650 Hull, Tubbies, Footholds, 650sx Motor & Pump, 1.75 over 663cc's, OP Comp Head 190psi, 44SBN, Vortex FA, WC Intake, Boyesen Reeds w/ Stuffers, Factory B Pipe, Factory Waterbox, 650 Side Exhaust, Dual Cooling, Billet Couplers, Jet Works FCV, OP 650sx Ride Plate, PJS Top Loader, Skat 9-17, -2" AM Pole, MSD total loss. 54mph.
    Special thanks to Chris Newmiller, and Mitchell at M&M Marine!
    Dec 2009
    Buffalo
    Re: JS300, 300sx questions
    You need motor mounts and a js300 (not sx) style pipe, also need to run a js300/440 drive shaft and pump
    Oct 2011
    Midland, Tx.
    Thanks. I have all the hull, and pump parts, just need the pipe.
    Dec 2009
    Buffalo
    I’m sure there is one around somewhere
    Frequent Poster joshuabbrown's Avatar
    Jan 2016
    Ga
    Depending on where the exit for the JS hull is you can rig something up with some exhaust hose. Other than that I thought the same mounts would work if you pulled it all from the SX hull.
    Anyone in South GA, lets ride.
    The Fleet:
    1990 650sx (minty fresh)
    1993 650 X2 (currently broke as hell)
    1990 JS550
    1986 JS550
