Results 1 to 2 of 2
    Misc yamaha parts need to go
    If you need anything here make me an offer. I need cash for winter projects.
    Std bore 62t cylinders. Almost runable, probably could run them but should be bored cause of a few scars. Pipe mounting surface is also worn out but that wouldnt matter with an aftermarket pipe.
    Stock 62t 701 head, very minimal pitting
    62t intake, great shape
    66e/800 core cylinder, very nice, hardly any plating damage
    Re: Misc yamaha parts need to go
    Weekend bump
