Results 1 to 10 of 12
    PWCToday Newbie b00st's Avatar
    Jun 2017
    IL
    Js550 to 750 electrical question
    So I finally got a 750 to swap into the 'ol js550 and I have a quick question.
    I did some research about the swap prior to buying the 750 engine and from what I read on the forums, people recommend using the stock js550 electronics with a 650 regulator.
    Just double checking to make sure this is correct.
    A lot of build threads I am seeing that have (had) wiring diagrams for this swap are no longer available due to photobucket
    On a side note I am starting to take pictures of the progress, and will try to make a thread once its all finished since nobody likes incomplete js550 builds. I have the ski almost stripped of paint and have the conversion brackets on the way.
    '85 JS550 - 750 swap in process
    '91 300SX
    PWCToday.com Is My Home Away From Home fastgtfairlane's Avatar
    charlotte,nc
    Re: Js550 to 750 electrical question
    some people have run the 650 electronics however the 750 electronics are much better. the only difference is not being able adjust your timing by rotating the stator which is the only real advantage to the 650 electronics and the smaller ebox. the 750 eboxs work with making a bracket work to bolt it to the stock 550 ebox location. the 750 cases have to be machined, drilled and tapped for a 650 stator to work. i recently put a dual carbed small pin out of a ssxi and used the stock ebox from the xi. modified the stock mounting bracket to work with the stock 550 ebox mount.
    91 440; PJS Viper 7000, jetsport exhaust mani, factory full pipe, coffman waterbox,solas 17*, jetco worked 440 pump, ocean pro nozzles. shredmaster ocean rideplate and grate combo, wide tray, footholds, deep strake mod, driveshaft fill,650sx quick turn
    build thread part 1: http://www.pwctoday.com/showthread.php?t=331343
    build thread part 2: http://www.pwctoday.com/showthread.php?t=364872
    build thread part 3: http://www.pwctoday.com/showthread.php?t=396154
    PWCToday Guru Rideallseasons's Avatar
    Aug 2013
    Up State NY
    If you have a 750 ss xi ebox. I bolted the cover directly to the 550 Ebox location. I made a seal for all the Mounting holes to hopefully prevent it from leaking (time will tell). It was a little PITA but learned next time should be easier. Firmly mounted and looks clean. IMG_3663.JPG
    charlotte,nc
    Quote Originally Posted by Rideallseasons View Post
    did you drill holes in the back of the ebox and bolt the back cover to the 550 ebox mount? it does look clean but how do you get it apart if you have to work on it? i wanted to mount mine horizontally like you did but im running the rhaas conversion plate with the stock 750 engine coupler so the engine is setting farther back than with the 550 coupler. im also running a js550 pump with the larget bulkier bulkhead bearing.
    due to lack of room i ended up mounting mine vertically but had to cut into the hood liner to get the hood to go down. i also bought the rhaas small battery plate and a smaller battery to give more room. with the ssxi box i was able to use a plug off the ssxi and use that access to power my bilge pump with a factory water sealed plug for easy removal and cleanliness. also used a plug for the start stop switch from the ssxi.
    Aug 2013
    Up State NY
    Drilled holes in the cover. I had to have the top box bolts in their holes before mounting the plate. My hull is an Sx with a JRE plate. I made a conversion plug for my Start Stop so I didn't hve to cut anything. I should have wires my bilge power to my Ebox power stud but didn't. Very tight but I can still unclip and unplug my pump from the westcoast bracket and waterproof connectors.
    Jun 2017
    IL
    Yes I have all the 750 electronics but I would like to use them on another project
    This is why I am wondering if the js550 electronics with a 650 regulator will work.
    Edit: now I am reading that the 750 regulator can be put in the js550 ebox to make it run the 750 engine.
    '91 300SX
    charlotte,nc
    ohh i see, i preferred modifying the stock bracket over drilling holes in the cover. i can also remove my ebox without first taking it apart in the ski which seems like it would be tough with the engine in. mine is pretty crammed but still pretty easy to work on.
    Quote Originally Posted by b00st View Post
    This could be interesting, post up some info on this if you can.
    PWCToday.com Is My Home Away From Home Bruce in SB's Avatar
    Santa Barbara, Ca.
    Quote Originally Posted by BLRider View Post
    Yeah... would like to see more about this swap ...
    "Thanks" to Chris Newmiller @ Newmiller Machine
    Mar 2012
    Altoona, PA
    yeah.. me too I was thinking about 750 swap also but was wondering about electrics also.. keep us informed thanks
