Results 1 to 10 of 11
    PWCToday.com Is My Home Away From Home Mike W's Avatar
    Apr 2003
    North Florida
    Kawasaki 650 Flywheel Puller Recommendation
    I have a puller I have used for years on my Yamaha motors but it doesn't work worth a damn on a Kawasaki 650 flywheel. The one I have boogers up the front of the crankshaft. Can someone post a pic or a link to a good puller for the 650?
    '03 Superjet
    '96 WB1
    '95 X2
    Mar 2011
    Brooklyn Center, MN
    Re: Kawasaki 650 Flywheel Puller Recommendation
    I use a $10 harmonic balancer puller from the autoparts store. Its pulled tons of flywheels off for me
    also on a 650 whatever puller you use yo need to put a nut or a small spacer between the puller bolt and the flywheel, whatever you use needs to be slightly smaller than the end of the crankshaft, that way it does not damage the crank.
    SE MI
    I've used the stock flywheel bolt as a landing point for my harmonic balancer puller, just leave it 4-5 threads from touching the face of the flywheel.
    Mar 2010
    Down by the river
    Quote Originally Posted by TMali View Post
    +1 for both!
    Rent one of these for free:
    http://www.autozone.com/loan-a-tools...kit/555524_0_0
    Dec 2014
    SRQ FL
    I bought the universal pwc flywheel puller kit on ebay for $15 or something like that and have been MORE than happy with it
    1992 Kawasaki SP 750sx - Big pin cyl, 1 mil overbore, Triton Engineering head, V-Force Carbon v3 reeds, Coffman Signature series pipe and silencer / WB bypass, dual SBN44 on R&D dual singles, Blowsion F/A, AC Racing -2 alum pole, Jetworks bars, full Jettrim, OP rideplate, Westcoast scoop grate, OP steer nozzle, blueprinted aluminum pump nozzle
    PWCToday Guru E350's Avatar
    Jul 2015
    Sacramento Delta, CA
    The ebay flywheel puller referenced below says that it has sufficient holes so as to be "universal" such that it will work for both Yamaha and Kawasaki.
    http://www.pwctoday.com/showthread.php?t=476901
    And although the Yamaha flywheel lock is referenced in the thread above, Cold Fusion makes and sells (and Blowsion sells) a flywheel holder specifically made for Kawasaki.
    Learning Slowly...
    Apr 2003
    North Florida
    Thanks for the suggestions fellas. I know what I was doing wrong now. I should be good to go.
    '03 Superjet
    '96 WB1
    '95 X2
    Aug 2011
    Austin, Texas, USA
    This is probably the best one on the market today: http://www.pwctoday.com/showthread.php?t=461951
    Riding mostly Lake Austin
    Jul 2015
    Quote Originally Posted by linkman View Post
    MrRogue: Even I can deduce function from the form of this tool. And it is frickin' awesome with the Rockwell hardness quoted. But is it really $500?
    I cannot justify that price.
    But my guess is that you could own the market at half that price if you were to take pre-paid orders for a high volume production run...
    Just sayin'.
    P.S. thanks to the linkman for posting this puller.
    Learning Slowly...
