Results 1 to 8 of 8
Thread: Js550
    Oct 2016
    Massachusetts
    Js550
    Might pick up a js550 with even compression 120. Says it won’t stay running, and needs a carb adjustment. $450 is this any good? Might part it out.
    Jun 2013
    Atlanta, Ga
    Re: Js550
    Depends on the state of the rest of the ski. Compression is a good indicator, but there are a whole host of things that wear out and must be tended to. Crank seals, impeller, pump housing, etc. $450 Is a decent price for a 550.
    Oct 2016
    Massachusetts
    Re: Js550
    Might buy it and part it out. Comes with pipes and stuff. Was thinking I'd probably be able to make most of my money back with the engine. Not sure though.
    Aug 2017
    Vancouver Island, Canada
    Re: Js550
    Quote Originally Posted by bendaggs View Post
    I wouldn't buy a used engine at 120psi.....its just about dead. oh ya, and "needs carbs adjusted" means I don't know what the F@#K is wrong with it!...So many things it could be, a F'd up engine being one of them (crank seals, air leak, etc)
    Dec 2009
    Buffalo
    Re: Js550
    120psi is not bad especially if its dead even
    Jun 2013
    Atlanta, Ga
    Re: Js550
    If it has a stock head, then 120 psi is really good. I have a reed engine with a Newmiller recreational milled head @168psi. Of course you can't tell that it is milled, it just looks like a stock head. That's kind of the gotcha. If the head is milled it could be 'down' 40 psi and in need of a rebuild. If it has an untouched head then it has good compression and the only concern will be the crank and crank seals' condition. Crank seals can be changed without taking the rest of the engine apart. While the crank case is open you can also assess the crank bearings.
    You can also inspect the cylinder walls by removing the intake manifold. You can see the side of the piston and the exhaust side of the cylinder wall.
    Bob
    Re: Js550
    If the rest of it is in good shape then i say thats a good deal. 120 is great for a stock js550.
    Aug 2017
    Re: Js550
    my bad, sorry to give wrong info... I had a 750 that had 120psi and it barely fired up before I rebuilt it, maybe the 550s need less psi, or maybe my gauge is busted.....LIke I always say to the nagging wife, A man can never have too many jetskis! so go buy it...lol
    Fun fact, do you know why us Canadians love have sex doggy style? So we can both watch the hockey game eh!
