Results 1 to 10 of 10
    Jul 2015
    Rockford, IL
    Broken exhaust pipe on 1993 750sx
    So I found out last night that the previous owner of my jet ski seemingly removed the bracket that supports the whole exhaust assembly off the front of the engine. Consequently, the entire thing was hanging off the exhaust manifold and finally broke off during a ride. It was the upper exhaust pipe that actually broke (look at part number 18049-3754). My riding is totally recreational, and while I'd love to have an aftermarket exhaust, I would prefer the cheapest solution to getting back on the water vs. the best solution for performance.
    At this point, my biggest problem is I can't find the stock part anywhere, and it doesn't even seem like anyone makes the aftermarket exhausts for 750's anymore either. I do see tons of the equivalent part for the 750ss engine of the same year. Does anyone happen to know if that part will work? It definitely looks different, but I can't tell if the interfaces are the same. Otherwise, does anyone happen to have a stock exhaust for a 750sx laying around that they would part with?
    I'm open to any other ideas as well
    Thanks,
    Brandon
    Dec 2009
    Buffalo
    Re: Broken exhaust pipe on 1993 750sx
    Post up in the want to buy section
    May 2011
    miami
    I may have the front bracket that was missing. Post a pic of the damage, maybe it can be repaired.
    Jul 2015
    Rockford, IL
    Pending sale on x-h2o, so I may be good. Here are some pictures, I wouldn't think it would be fixable, but I'm no expert.
    Oh snap !
    May 2011
    miami
    Lol yep, that's trash
    Jul 2015
    Rockford, IL
    So follow-up question - is the metal gasket between the exhaust manifold and pipe (right where mine broke) supposed to have the circumferential slots like to two pieces it goes between? Mine was solid...is there water or air that's supposed to flow between the two pieces?
    May 2011
    miami
    No, that gasket should be solid. Water is in those 2 jackets but nothing is supposed to pass through.
    Jul 2015
    Rockford, IL
    Ok, should I be replacing any disturbed gaskets, or are they ok to reuse?
    May 2011
    miami
    I'd replace them while it's apart. Who ever wants to do it twice
