98 Seadoo GTX RFI mag injector not working
    PWCToday Newbie Jlstreccius's Avatar
    North Dakota
    I have a 98 GTX RFI project that I am puzzled with. I bought this ski as a project and rebuilt the motor, new pistons rings, crank seals, etc. the only history I have on the machine from the original owner is that it was a lemon. After reassembly. It starts poorly and only idles on the PTO cylinder. There is good spark on the MAG side. All sensors test good. I pulled the injector rail and fuel only sprays on the PTO injector. At half throttle or full throttle the result is the same. I switched wiring on the injectors and the Mag injector sprays the same as the PTO at all positions of the throttle but still only one injector sprays. When the ski is running the Maintenance light is flashing. I have attempted to rest but it continues. I took the ski to a certified mechanic/friend who does side work at home and has the electronics to test the system. He thinks it may be the MPEM but is not convinced this will fix it.
    One additional concern from the rebuild I have is that I removed the magnet ring on the flywheel, thinking this was necessary for flywheel removal. If the ring was installed incorrectly could this cause the injector problem? I was confident when reassembling that I got it right but now I am not sure? Please help.
    Additional question: Can the MPEM be sent out for testing?
    PWCToday.com Is My Home Away From Home bills86e's Avatar
    May 2008
    florida
    Re: 98 Seadoo GTX RFI mag injector not working
    Get a free shop manual for your 98 787 GTX RFI from the Sticky. Yes - Minnetonkaforme. Nick@westsidepowersports.com
    PWCToday.com Is My Home Away From Home Chester's Avatar
    Feb 2002
    Vancouver, BC Canada
    Sea-Doo RFi engines run on only one cylinder at idle. How does it run on the water?
    Chester
    Speed is very expensive. How fast do you want to spend?
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    North Dakota
    Quote Originally Posted by Chester View Post
    Chester
    It does not run in the water.
    May 2008
    florida
    RFI's will not run on pre-mix fuel and do not like water in fuel or old fuel. Check air pump. Lub lines. Switch the Injectors and re-check.
    Test compression, *plugs.
