96 gsx bad starter? - Page 2
Results 11 to 16 of 16
    Re: 96 gsx bad starter?
    Starter bolt will not help you with a bad ground cable. You would need to test at the battery negative. Starters can go out all of the sudden. Wires can break off brushes and worn brushes can stop making connection at a moments notice.
    The brand new starters available are not that reliable. Unless you buy say SBT or a few others. Rebuilding and old Denso OEM starter is the best solution. I have only ever had one that I could not rebuild due to a starter malfunction.
    SBT Seadoo starters are junk !!
    May 2009
    South Carolina
    If you are missing ground the starter solenoid would not click--you are correct. By jumpering the solenoid post (large red wire-battery to Large red wire starter) you are eliminating the solenoid. When you jumper the solenoid check the voltage across the battery and then from the battery negative to the starter hot post. If the voltage stays at no load voltage (12.5 volts) then you starter is probably bad. You can check the ground cable by hooking a meter (in ohms) to both ends of ground cable and wiggle it to make sure you do not loose continuity(maintain roughly 0 ohms).
    It is really odd to think an OEM starter would be bad after 6 months unless you use you ski a ton and have trouble starting it.
    I have had decent success with the few SBT starters I have used.
    Think Big!!
    Frequent Poster daget24's Avatar
    Feb 2013
    santa barbara
    Hey guy figured I’d just give a resolution to this thread. It was the starter. I have no idea why considering this was a brand new OEM starter from a Seadoo dealer that didn’t last more than 6 months, but yeah it was the starter.
    1 2014 seadoo GTR
    1 1996 seadoo gsx
    Jun 2011
    Thanks for posting the result!
    What starter did you end up going with? Another OEM, SBT or ? Also, can you return the ďnewĒ defective OEM starter for some store credit or something similar?
    What would Chuck Norris do?
    Feb 2013
    santa barbara
    I ended up just getting a used OEM one off eBay for like $30, works great. I taking to the dealership, there is apparently no warranty at all if they did not install it, I’ll just rebuild the thing and keep it around as a spare, but super frustrating for sure. Especially when you factor that the starter was $300+ new. ��
    1 2014 seadoo GTR
    1 1996 seadoo gsx
    Jun 2011
    Well Iím glad you were able to get a good used one and rebuild the other and keep as a spare.
    Itís a sh!tty deal(or really no deal at all) from the dealership. But I guess make the most out of a bad situation and ride the heck outta that ski !
