96 gsx bad starter?
Results 1 to 10 of 16
    Frequent Poster daget24's Avatar
    Feb 2013
    santa barbara
    96 gsx bad starter?
    Hey guys, so today I was riding my 787 gsx and works and runs great, but I turned it off at the end of the day and when I went to flush the motor later it wouldnít start. Here is the symptom, the starter selinoid clicks but the starter does nothing, doesnít spin at all. So I tried jumping the two terminals inside the black electrical box and that didnít do anything so Iím thinking I have a bad starter, but that just seems odd as I replaced it with a brand new one 6 months ago, all the wires are newer and the the connections are tight.
    So where do I look next?
    1 2014 seadoo GTR
    1 1996 seadoo gsx
    Feb 2013
    santa barbara
    Re: 96 gsx bad starter?
    Brand new OEM starter.
    Jun 2011
    Put your red test lead from your meter on the red cable at the starter and Ground the other lead.
    Push the Start/Stop button.
    Are you getting 12v?
    What would Chuck Norris do?
    Feb 2013
    santa barbara
    Idk why the hell I didn’t think to do that, I’ll check tonight.
    1 2014 seadoo GTR
    1 1996 seadoo gsx
    Jun 2011
    No worries! It happens to all of Us!
    Let Us know what you find out...
    Sounds like a bad ground cable.....
    Feb 2013
    santa barbara
    Hey it’s grumpy old guy! What’s up man, long ago, you rebuilt my carbs!
    So yeah 12v is getting the starter, had a buddy hold that starter button down and verified 12v is getting the starter post. Alright I was asking a head bold for my ground and not the starter bolt.
    It’s just weird, the starter does NOTHING.....
    1 2014 seadoo GTR
    1 1996 seadoo gsx
    May 2009
    South Carolina
    Starter bolt will not help you with a bad ground cable. You would need to test at the battery negative. Starters can go out all of the sudden. Wires can break off brushes and worn brushes can stop making connection at a moments notice.
    The brand new starters available are not that reliable. Unless you buy say SBT or a few others. Rebuilding and old Denso OEM starter is the best solution. I have only ever had one that I could not rebuild due to a starter malfunction.
    Think Big!!
    Feb 2013
    santa barbara
    No that’s the thing though this is a 6month old starter that is OEM and that I bought brand new from a dealer for like $400
    1 2014 seadoo GTR
    1 1996 seadoo gsx
    Feb 2013
    santa barbara
    And if I had a bad ground wouldn’t the starters Selinoid not click? I mean I’m getting 12v to the starter itself when someone is holding the start stop.
