650sx FPP running problems - Page 5
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 57
  1. #41
    Top Dog bandit88's Avatar
    Green Bay WI
    Re: 650sx FPP running problems
    I would have took the OEM or any quality cast piston over Wiseco, but they will work good, just make sure who ever is doing the machine work sets the proper clearance and you slowly warm the motor up before riding. If you use OEM specs you will seize them.
    -95 750SXI
    -90 TS650
    -91 300SX
  2. #42
    Frequent Poster 92Kawasaki750SS's Avatar
    Jul 2015
    United States
    What is a "quality" cast piston brand? I thought I read people prefer Wiseco over WSM?
    Sent from my SM-N920V using Tapatalk
  3. #43
    Green Bay WI
    I would take OEM, ProX, and WSM over Wiseco in any ski. Victor Sheldon's SXI Pro with the 785 stroker that made 160 HP ran OEM cast pistons. On a 125 or 250 dirtbike I may change my mind, but not on a cool running ski motor.
    With that said, I have one PJS800 motor with Wisecos and they have been working good. They were in there when I bought the motor, and I know Newmiller set them up right. Im still very easy on it while its getting warmed up.
    -95 750SXI
    -90 TS650
    -91 300SX
  4. #44
    Jul 2015
    United States
    My bore measurements... give or take a thousandth maybe... If anything that rear cylinder is smaller than the front... ( rear is the one that seized )...
  5. #45
    charlotte,nc
    wsm pistons rings and top end bearings would be fine just use oem gaskets especially the head and base. oem should be .010 stamped stainless with a coating that are crush gaskets. the thinner gaskets will both keep the compression up and lower exhaust port timing for better bottom end.
  6. #46
    Jul 2015
    United States
    Progress... waiting on parts npw...
  7. #47
    Jul 2015
    United States
    What kind of grease do you recommend putting on the crank seals? I noticed t there is grease between the outer seal and the one crank seal. When I install new seals do I need to apply any sealer to the surface where the seals meet the crank case halves or leave it dry?
  8. #48
    Green Bay WI
    I just use regular marine bearing grease that I use for my trailer. Grease the inside lips and full about 1/2 seal between the two on the PTO side. I put just a dab of 1211 on the outer lip of the seals where the seam is between the two case halves, otherwise the rest of the outer lip is dry.
    -95 750SXI
    -90 TS650
    -91 300SX
  9. #49
    Jul 2015
    United States
    Can the marine grease and 1211 be found at local auto parts store? I have a Westmarine pretty close, like 45 minute drive one way but can go there if needed.
  10. #50
    Green Bay WI
    The grease yes, the 1211 no. West Marine or a hardware store might have something similar like Permatex MotoSeal.
    -95 750SXI
    -90 TS650
    -91 300SX
