650sx FPP running problems - Page 3
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 57
    charlotte,nc
    Re: 650sx FPP running problems
    yamabond, hondabond, i bet theres a kawibond too. they are all based off threebond 1211. use it for the case halves. if you go with oem gaskets then just clean the surfaces and install the gaskets dry. both the head gasket and base gasket. the 1211 will probably be a little more expensive but your local jetski, motorcycle shop will stock the yamabond.
    Frequent Poster 92Kawasaki750SS's Avatar
    Jul 2015
    United States
    If Hondabond HT will work I have access to that. I'm an Acura technician, Hondabond HT I a silicon sealer. I thought I read somewhere not to use silicon on 2 stroke stuff. But more than likely I'll use OEM gaskets....
    Sent from my SM-N920V using Tapatalk
    charlotte,nc
    i think 1211 is a silicon sealer as well. might double check maybe you can get a listing of what its made of and compare to the hondabond you have access to and see how similar they are.
    charlotte,nc
    i just did a quick search for you both are silicone based liquid gasket makers for the same applications. so you should be good to go.
    Jul 2015
    United States
    Thanks, at least I don't have to buy that lol... Thanks for all the help.
    charlotte,nc
    haha i know right especially just for the cases.
    Top Dog bandit88's Avatar
    Green Bay WI
    Just make sure its a anaerobic sealant.
    -95 750SXI
    -90 TS650
    -91 300SX
    Jul 2015
    United States
    Well, here's the problem... Rings seized on piston. Cylinder looks like it can be honed... piston surprisingly isn't scored too bad. Group K website DOES recommend leaks down before dissasbly to see if there are any leaks. I pressure tested to 10psi and it held for 5minutes with no leakage. I'm pretty sure I ran lean due to lack of carb adjustment. And I haven't rebuilt the carb yet quick I will do now.
  9. #29
    Green Bay WI
    Replace the seals, they are old and a leakdown test is next to worthless since it only checks that the seals hold pressure. They need to hold vacuum as well and if they cant, that will also cause you to run lean.
    -95 750SXI
    -90 TS650
    -91 300SX
  10. #30
    Feb 2002
    Vancouver, BC Canada
    TB-1211, yamabond, and hondabond are silicone based and are not anaerobic. Loctite 515 and 518 are aenerobic but not recommended.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
