Results 11 to 20 of 57
    charlotte,nc
    Re: 650sx FPP running problems
    i would close the bottom and middle and just open the top for best bottom end. try 3/4 turn on the top screw. it will keep the head pipe cooler for better bottom end. the bottom screw allows the headpipe to run a little warmer which will raise the rpm hit up and less bottom end but will give more rpms on top. your bottom screw being open is probably where the loading up is coming from because when the ski sits the water gravity feeds down and with that bottom screw open its letting water into the exhaust stream when the ski is off.
    if you really want to increase the bottom end, run a dedicated cooling line to the pipe so youre getting fresh cooler water directly from the pump and not first preheated through the engine. then run a flow control valve which will limit water going into the water box at lower rpms. then you could close your screw a little more and still get good bottom and top end power. with this setup on my 550 with a tunable factory headpipe setup, i had the bottom and middle screw closed and the top just 1/2 a turn.
    Frequent Poster 92Kawasaki750SS's Avatar
    Jul 2015
    United States
    Well, just did compression check and I have like 190 in front cylinder ( stock milled head by NewMiller earlier this season ) and only 50 or so in rear cylinder. Pulled the head and see absolutely to reason for loss of compression. What should I check?
    Sent from my SM-N920V using Tapatalk
    SE MI
    How does the cylinder wall look in the rear cylinder?
    Jul 2015
    United States
    It doesn't looks really bad, but it deffinetly looks worse than the front. There are more lines in it, looking like the rings starting to score. I don't know jet skis well but my only other thought would be the reeds broke or something for that cylinder. I re-installed and torqued the head and got the exact same reading as stated above. I might check the reeds tomorrow but I'm thinking it's time for a new top end. I have put about 30 hrs or so on this thing in two seasons and 20 or so have been with the high compression head this season. And I haven't been exactly nice yo this poor old thing.
    Jul 2015
    United States
    Ok, so before I take the cylinders off I'm gonna do a leakdown test to check for any major leaks and see if the crank seals are good. Anything else I should do before removal?
    charlotte,nc
    might get lucky and just have to hone the cylinders. i recently bought a 750 small pin that had low compression in one of the cylinders but i didnt see any bad spots on the cylinder walls. just ordered new pistons with rings, and top end bearings and just went through the entire engine and had a friend do a quick cylinder hone. has equal compression now and is running strong. since you know one cylinder has low compression, cheap insurance would be to go ahead and put in new crank seals as well. no real need to do a leak down test if you already have low compression on 1 cylinder.
    Jul 2015
    United States
    But why split the lower crank case if the seals don't leak? And IF the piston looks good I may just do rings. Idk yet, I also HATE doing things twice and not doing thing right the first time. This engine is 26 years old and never been rebuilt so maybe it's time for new rubber seals.
    Jul 2015
    United States
    Rings and hone cylinder at the least....
    charlotte,nc
    if those are the original crank seals and you are pulling the cylinder apart, why wouldnt you do the seals when youre that much apart? seems like cheap insurance to me. being those are the original seals i wouldnt waste the time doing a leak check. probably a little more than 2 hours to split the cases, clean everything and reinstall. then youll 100% know it couldnt be an issue. i think i spent just over 300 bucks for a complete top end kit pistons, rings, bearings and complete gasket kit with seals. wouldnt use anything other than oem kawi gaskets. partzilla.com has all oem kawi stuff. i went with sbt cast pistons on mine just because a buddy owns a jetski shop and i got his discounts.
    Jul 2015
    United States
    Ok yeah, I'll look into it. I've got all winter now. Any suggestion on sealer for the lower case halves?
