Results 1 to 8 of 8
    PWCToday.com Is My Home Away From Home IceRocket1286's Avatar
    Nov 2003
    Detroit
    1994 Squarenose 785 B Pipe AC Pole $2k Michigan
    First and foremost, This ski belongs to my friend, I am posting it for him.
    1994 Squarenose - non running condition
    AC Aluminum pole, UMI steering etc.
    Exotic Signs Graphics
    785 Big bore, this is a 61x motor
    Factor B pipe
    ADA Racing head with extra domes
    Aluminum roundnose waterbox
    Brand new RHAAS motor mounts
    ADA aluminum coupler with SXR dampener
    Pro Tec ride pate and scoop grate
    Motor was brand new, my friend was out for a ride when the motor mounts let loose, also ruined the couplers. Ski was towed in. Ski was supposedly winterized properly but clearly was not. When I went to install the new coupler on the motor, I realized the motor was locked up. Crankcase full of water from being towed in, and the ski was never properly winterized. My buddy that owns the ski is not mechanical at all and has no garage to store the ski. He has a little over $3k into it because it blew up right when he got it and it was rebuilt. He no longer wants to put money into this ski. Only thing left thats good is the head and cases. Cylinder and pistons are damaged from freezing and being locked up. This is a total bummer for my buddy but it is what it is.
    This ski is a perfect part-out ski for someone who has the time and space, which I do not. It is also a perfect ski to drop a stock 701 or spare motor in and have for fun. If I hadn't bought a new house recently, I'd buy it from him.
    He's asking $2k OBO. Located in New Baltimore, MI. Please PM with interest.
    IMG_5381.JPGIMG_5393.JPGIMG_5392.JPGIMG_5391.JPGIMG_5390.JPGIMG_5389.JPGIMG_5388.JPGIMG_5387.JPGIMG_5386.JPGIMG_5385.JPGIMG_5384.JPGIMG_5383.JPGIMG_5382.JPGIMG_5394.JPG
    See the all new BAM Hull and test ride for yourself!
    http://www.crazyjoescustoms.com/
    Re: 1994 Squarenose 785 B Pipe AC Pole $2k Michigan
    It appears youre mechanically inclined and hes your buddy. Do him a favor and help him fix it. Cost of parts will be minimal.
    Michigan
    I dig the Square SJ.. These skis are a good value for someone looking to own a Super Jet.
    Nov 2003
    Detroit
    We have discussed repairing it and I would do so free of charge, no problem at all. He just doesn’t want to put the money into this ski anymore.
    Bump for a nice ski
    OBO
    PWCToday Guru E350's Avatar
    Jul 2015
    Sacramento Delta, CA
    Freezing water is a powerful force. Would you mind posting up pictures of the freeze damage to the crankcase, etc.?
    Learning Slowly...
    Nov 2003
    Detroit
    Quote Originally Posted by E350 View Post
    I will take some photos tonight when I get home, but as far as I could tell the cases are fine. There was not enough water in the cases to freeze and cause damage. Certainly enough to ruin some bearings.
    Sep 2007
    Utah
    does it have a trailer?
    Nov 2003
    Detroit
    No trailer available. Thanks.
