    Frequent Poster Waveblaster16's Avatar
    Jun 2009
    St. Louis MO
    760 Starter Replacement Trouble
    I have a 760 from a waveraider in my blaster, and it randomly wouldn't start while riding a bit ago. Finally got some time to diagnose it since all I heard was a click. The starter had 12 volts and was not moving at all. I tried jumping the starter and nothing so I decided to replace it. Ordered one http://www.ebay.com/itm/FITS-YAMAHA-...72.m2749.l2649
    I have the protec exhaust on and for the life of me can't get to two bolts on it so I replaced the starter with it on. Anyway I got the new starter on and tightened down and it's not in all the way from what I can tell. It has power now but just spins without engaging so I assume it needs to go in that little bit more but the bolts are tight. I've replcead a few starters before so not sure what the problem is. Hopefully I'm doing something dumb just seeing if you guys have any insight.
    1996 1100 zxi - stock other than premix
    1994 Waveblaster - 760 engine, protec pipe, protec head, dual 44 sbn's, solas impeller, groovy ride plate, protec scoop grate, aluminum waterbox
    1986 X2 - in pieces...
    www.fatmaxracing.com - Buy a poster!
    Re: 760 Starter Replacement Trouble
    The only mistake you made was buying a $35 starter & expecting it to work.
    Buy a real starter (oem) if you dont wanna do it every time you ride.
    PWCToday.com Is My Home Away From Home Chester's Avatar
    Feb 2002
    Vancouver, BC Canada
    It's in all the way. Get a better starter (OEM). If it's just spinning, you may need a new reduction gear too.
    Chester
    Speed is very expensive. How fast do you want to spend?
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
