    Frequent Poster Waveblaster16's Avatar
    Jun 2009
    St. Louis MO
    760 Starter Replacement Trouble
    I have a 760 from a waveraider in my blaster, and it randomly wouldn't start while riding a bit ago. Finally got some time to diagnose it since all I heard was a click. The starter had 12 volts and was not moving at all. I tried jumping the starter and nothing so I decided to replace it. Ordered one http://www.ebay.com/itm/FITS-YAMAHA-...72.m2749.l2649
    I have the protec exhaust on and for the life of me can't get to two bolts on it so I replaced the starter with it on. Anyway I got the new starter on and tightened down and it's not in all the way from what I can tell. It has power now but just spins without engaging so I assume it needs to go in that little bit more but the bolts are tight. I've replcead a few starters before so not sure what the problem is. Hopefully I'm doing something dumb just seeing if you guys have any insight.
    1996 1100 zxi - stock other than premix
    1994 Waveblaster - 760 engine, protec pipe, protec head, dual 44 sbn's, solas impeller, groovy ride plate, protec scoop grate, aluminum waterbox
    1986 X2 - in pieces...
    www.fatmaxracing.com - Buy a poster!
    Re: 760 Starter Replacement Trouble
    The only mistake you made was buying a $35 starter & expecting it to work.
    Buy a real starter (oem) if you dont wanna do it every time you ride.
    Feb 2002
    Vancouver, BC Canada
    It's in all the way. Get a better starter (OEM). If it's just spinning, you may need a new reduction gear too.
    Stand up:
    98 SXi-Pro
    96 XP
    86 X2
