    Aug 2017
    North Dakota
    How to remove 1988 x2 waterbox
    I'm at a loss, and have searched on here. I see the welded nuts on the waterbox brackets but can't figure it out? Any help would be awesome.
    Aug 2010
    Australia
    Re: How to remove 1988 x2 waterbox
    when you get the fuel tank out you get a better picture of what is needed to be done , remove the filler neck and rubber hose,to do this ,remove the 4 screws from the filler neck and loosen the hose clamps > un clip the rubber retaining straps > take out the tank , remove the 2 exhaust hoses ,it is easier if you take the hoses from the ski ! . , unclip the 2 rubber retaining straps and remove the entire water box rubber feet included ,
    modded X2 650
    Originally Posted by hyosung
    Aug 2017
    North Dakota
    Thanks hyo!
