Results 11 to 20 of 25
    Jun 2011
    Napa
    Re: Brand new 2017 Factory Pipe for X2
    Quote Originally Posted by lightemup67 View Post
    Pull the trigger, think about the potential upside (smiles ear to ear while riding) vs. having $500 locked up for under 30 days. It probably wouldn't even hit your CC statement until next month, if it doesn't reach 50, you'll get your money back. If you have a x2 without a factory pipe, you're missing out!
    LOL, right, but sadly I am one of those guys who already has more factory pipes than running skis. I have 2 running skis-
    One of which is my 94 x2 with a 650sx factory pipe!
    - John Kenneth Galbraith
    Aug 2017
    US
    Current order count is 35, with no new orders in the last 48hrs.
    Sent from my SM-G935V using Tapatalk
    Mar 2007
    Is Everything!
    This is why most of these fail.... a bunch of hot air from blow hards.
    There are two more in the hole for your order if you can simply answer the questions I posed. Or shall I call the manufacturer?
    PWCToday.com Is My Home Away From Home Mike W's Avatar
    Apr 2003
    North Florida
    Where did you post your question?
    '03 Superjet
    '96 WB1
    '95 X2
    PWCToday.com Is My Home Away From Home garrcass's Avatar
    Jun 2011
    Redding CA
    17
    Hmm I might be in if I can get some concrete info on limited vs mod and Maybie a volume for each one. Wondering witch one I have been running all these years.
    ( Girlfrends are cheap X2,s are expensive )
    Mar 2007
    Is Everything!
    Quote Originally Posted by Mike W View Post
    PM to proposed distributor.
    Quote Originally Posted by garrcass View Post
    Yup. Overall shape is a big factor for me too. Seems that the potential diff is very similar to the LMTD vs MOD SJ chambers. However much like you, speculation doesn't work as I want to know for certain as I will not be installing them conventionally with regards to 650sx/X2 engine/hull.
    Aug 2007
    http://www.pwctoday.com/showthread.p...t=#post4238270
    Hey J, this is a pic I came across with the 2 versions next to each other. The lengths are listed a few posts down.
    Mar 2007
    Is Everything!
    Thanks freek. That was very helpful, much better than the non answers through the 10,000 threads about this deal. It appears to me there is a lot more to the diff than just length based on the pics.
    Jun 2011
    Redding CA
    17
    Seems I all ready have the large version..
    Sep 2017
    Saskatchewan
    Curious what everyone is using for 90 degree elbows out of the pipe to the waterbox? Just using the stock aluminum 90's? I was thinking of replacing them with a generic silicone 90 degree hose.
