    PWCToday Guru E350's Avatar
    Jul 2015
    Sacramento Delta, CA
    Best Bilge Switch for X2 with UMI Racing Handlebars ?
    My wife's 1988 X2 has the X2 vertical Kawasaki start/stop switch on the left handle bar. It also has a motorcycle hand brake type lever for the nozzle trim on the left handle bar. I am not sure that there is enough room between the start/stop switch and the handlebar grip on the left for a Blowsion universal bilge switch:
    https://www.blowsion.com/products/hu...ndle-bar-mount
    It had a 29-year-old pushbutton round three-wire bilge switch of a type I have never seen before which was mounted below the UMI Racing horizontal brace. And it finally failed this afternoon, almost sinking the ski.
    Learning Slowly...
    I dream skis RaiderMagic's Avatar
    Aug 2013
    South Shore, Long Island
    8
    Re: Best Bilge Switch for X2 with UMI Racing Handlebars ?
    what you pictured is the best switch available. It is Mil -pec & very nice. I had one on my last x2.
    the 3 button s/s sw. you have is likely from an stx, Ultra etc. The yellow was to control trim on some models. It's a big switch overall.
    IMO the 2nd best Bilge on the market is the Rotary 3 way switch. Blowsion & someone else makes it. same thing from like 3 co's.
    These are about $35, waterproof, etc.
    http://www.iboats.com/Three-Way-Pane...SABEgJo4PD_BwE
    TIP: mount it on the left side so you dont have to left of throttle to turn on/off. I wire it so middle is off, Left & Right position are on.
    96 Waveraider 1100(sold)
    96 WaveBlaster 2 (sold)
    94 Xi -donor/parting
    99 Ultra 150- F/S
    92 SN 701
    88 X2 750
    93 X2 650 (sold)
    04 GP 800R
    03 XLT 1200
    Jones Inlet, LI
    Jul 2015
    Raider I went with this switch because it is an aluminum body and is not very tall which I can put in the exact same place as the existing switch:
    Attachment 531171
    http://www.ebay.com/itm/New-Pwc-Jets...53.m2749.l2649
    We will see if it holds up as well as the prior switch did. BTW I did put the Blowsion switches for the Superjet (horizontal under the Yamaha start/stop switch) and the 550sx (horizontal under the Kawasaki start/stop switch).
    Learning Slowly...
