Results 1 to 2 of 2
    Feb 2016
    Tampa, Florida
    Break in oil for 4 stroke????
    Is here a good break in oil for an FXcruiser engine? Just built it, should I just use 40 weight and change it ?
    Re: Break in oil for 4 stroke????
    I usually break in with Castrol 10-30. About 8-10 hours then change it and run synthetic.
