    Aug 2017
    FL
    which of these 2 ride plates for js550
    I am new to riding a standup and I am still working on the basics, turning to the right is my next thing to concure. Right now the ride plate on it says PRO on it, is solid with ridges on the bottom. The other one I have is an ocean pro, it is slightly longer than the other one (5-10mm), it has a hole on the middle of it and the bottom is flat. I understand that different ride plates do different things. I am just not sure which one would be better for a beginner. Also should there be silicone along the sides of it? the one i took off only had it on the front side by the intake grates.
    PWCToday Newbie skidooseadoo's Avatar
    Jun 2016
    Ontario
    Re: which of these 2 ride plates for js550
    Ocean pro extended plate may be your best bet.
    Dec 2009
    Buffalo
    The ridged one probably is a finned and the other with the hole is the "race" plate. I always preferred the longer flat one with the hole (race plate)
    Oct 2006
    under a ton of work
    Try them both and see which you prefer.
    you can silicone it once you have chosen.silicone also help retain the plate if the inserts fail.
    Aug 2017
    FL
    thanks for info
