Results 1 to 8 of 8
    Top Dog bandit88's Avatar
    Green Bay WI
    Victor Sheldon 1998 World Finals Motor
    Im selling a ultra rare team kawasaki powervalve motor that is believed to have been pulled from Victor Sheldon's SXI Pro after the 98 World Finals. This motor is basically a +3 stroker small pin 750 with a different cylinder and head. Total displacement is 785cc. Motor comes with: Crank, crankcases, cylinder, pistons, head, exhaust manifold, dry pipe, front cover, and what is left of the powervalve controller. I was told the original electronics died long ago. This motor does need some work, but it is just about one of a kind.
    Crank: Is a SP crank that uses SP rods. Has a +3 stroke. Needs rebuild as bearings are noisey.
    Crankcases are heavily ported SP cases. Has a special serial number and drain holes were never machined out.
    Pistons: are 1st over SP pistons with modified Skirts. - Has some scoring and should be replaced.
    Cylinder: is one off, has powervalves which operate smooth. All aluminum with plated bores. Plating is in good shape. The top deck on the cylinder needs some repair work on the waterjacket sealing surface. Piston sealing surface is good.
    Head: Also one off, needs a little repair to one of the domes.
    Exhaust: overall nice shape, doesnt seem to be any internal leaks and holds pressure.
    PV controller: Probably not any use anymore, but is included.
    This with a set of Novi carbs, is supposed to be at 160HP. Hate to sell it but im buying my first house and some extra cash would be nice. $1000 shipped for a historic piece and a motor that will get you to outrun the new SXR. Pics can be seen at: https://www.amazon.com/photos/share/...Tc4X5YSvbdgQdJ
    -95 750SXI
    -90 TS650
    -91 300SX
    PWCToday Regular Slough Burner's Avatar
    Aug 2017
    WA
    Re: Victor Sheldon 1998 World Finals Motor
    Very Cool!
    Green Bay WI
    bump open to offers
    -95 750SXI
    -90 TS650
    -91 300SX
    Green Bay WI
    bump
    -95 750SXI
    -90 TS650
    -91 300SX
    Green Bay WI
    bump
    -95 750SXI
    -90 TS650
    -91 300SX
    Dec 2005
    Wisconsin
    5
    bump open to offers
    I offer to help you install this motor in a super chicken and then send it.
    WHEN IN DOUBT, GAS IT!
    Green Bay WI
    Better yet, I will help you install it in a square nose.
    -95 750SXI
    -90 TS650
    -91 300SX
    Green Bay WI
    Sold on Facebook
    -95 750SXI
    -90 TS650
    -91 300SX
