650sx high compression
    PWCToday Newbie ealbertson98's Avatar
    Mar 2017
    Wake Forrest NC
    I just picked up a 650sx with a 44mm carb, west coast pipe, and intake and exhaust manifolds. the ski is running 180 psi in both cylinders with stock decked head I'm assuming. My question is there special procedures I should go by because of the high compression, I've only had stock 650sx with 150 compression.
    2005 Kawasaki Ultra 150
    1989 kawasaki x2
    1990 kawasaki 650sx
    1994 kawasaki 750ss
    Frequent Poster 92Kawasaki750SS's Avatar
    Jul 2015
    United States
    Re: 650sx high compression
    Should be fine using highest grade pump gas and 40:1 mix.
    Dec 2006
    Mesa AZ
    Quote Originally Posted by ealbertson98 View Post
    Hold on tighter when you pull the throttle.
    Mar 2017
    Wake Forrest NC
    Appreciate y'all always got the answer
    1989 kawasaki x2
    1990 kawasaki 650sx
    1994 kawasaki 750ss
