Results 1 to 10 of 13
    PWCToday Guru E350's Avatar
    Jul 2015
    Sacramento Delta, CA
    Best Gasket Sealer(s)?
    I am going to vacuum test the 650cc engine in my wife's X2. For the test, I plan to remove the exhaust to pipe gasket and also remove the carburetor to intake manifold gasket and temporarily replace them both with 1/16" thick rubber sheet in the same shape as the removed gaskets.
    [Note: There has been a little setback regarding the aluminum exhaust manifold to pipe portion of this job because one of the three bolt holes is stripped because the prior owner cross-threaded 10mm 1.50 pitch bolts into the 10mm 1.25 pitch manifold bolt holes. But I digress.]
    This is what Group K says about air leaks due to gaskets without sealer:
    "Intake gaskets, particularly ones with no sealer on them, are always candidates for small air leak"
    http://www.groupk.com/tec-airleak.htm
    ABOUT AIR LEAKS - The engine you save could be your own
    So my questions are:
    1. What is the best sealer, if any, for gaskets on the intake side of the engine? and
    2. What is the best sealer, if any, for gaskets on the exhaust side of the engine? (I noticed that there was some sort of silicone on the manifold to pipe gasket when I removed it.)
    I know I am asking basic questions, but I appreciate all your help.
    Learning Slowly...
    Frequent Poster JustStandups's Avatar
    Sacramento
    Re: Best Gasket Sealer(s)?
    Three bond 1211 is what everyone has told me, it's all I use on 2 stroke. It's pricey but ive never had a leak and looks like what I've seen on lots of factory motors.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    VHP7000 #132 T1
    VHP7000 #169 T3
    VHP7000 #174 project PJS Triple 795cc
    550sx PJS all over w/ 440 fully ported
    SE CT
    Best to reseal then test.Just my two cents.I like yamabond.
    R.I.P. Super Sic
    Jul 2015
    AC 46: I looked it up and on ebay there is Yamabond 4, 5 and 6B? So, which ones and for which application intake and/or exhaust?
    Learning Slowly...
    Chicago / Portage, MI
    +1 For Threebond 1211. We have used it without incident on every engine we've built since about 2010.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1998 SXI PRO:
    3DR hull mods [TBD]
    May 2011
    Minnesota
    I've been using yamabond 4 for years and never had an issue. It's way cheaper than threebond.
    http://www.ebay.com/itm/Yamaha-Yamal...72.m2749.l2649
    SE MI
    Three bond 1211 is my first (only) choice.
    Top Dog bandit88's Avatar
    Green Bay WI
    I personally would not use threebond for anything except case halves. If everything else is decent its not needed. Install gaskets dry, if they are fiber/paper gaskets I coat them in grease first for easy removal when I want to change them. No sealant on intake gaskets, exhaust gaskets, head gaskets, etc.
    -95 750SXI
    -90 TS650
    -91 300SX
    Jul 2015
    To All whom have posted so far and (hopefully) will post later. I ordered some Three Bond 1211, but I also read the reviews (excellent) on Amazon, and my natural inclination in these things is to do what bandit88 suggests, use Three Bond 1211 (if needed) for case halves and nothing for intake or exhaust. That is apparently how this engine was rebuilt. If my vacuum test reveals that the case is not leaking without Three Bond, I will not use it on the case halves. Because I want to be able to open and separate the case halves and other things without damaging them by having to use pullers, sledge hammers, screw drivers, etc.
    Since I am now the proud owner of a Mitivac 8510, my idea is to vacuum test through the pulse line all of our engines every couple of years or so and replace crank or flywheel seals as needed and I would like to do so with the least violence to the case as possible. Because, correct me if I am wrong, the case is the least likely leak culprit, while the crank seals are the most likely. And no amount of Three Bond 1211 or Yamabond on the case halves will prevent crank seals from leaking?
    Learning Slowly...
    Green Bay WI
    You must use the threebond on case halves. They will leak otherwise. Nothing else needs sealant.
    -95 750SXI
    -90 TS650
    -91 300SX
