Results 1 to 10 of 12
    PWCToday Newbie 09dewaed's Avatar
    Aug 2017
    Philly
    what is the best adhesive for hydroturfing an old ski?
    I'm looking to clean up my 650sx and get some new plush padding and turf installed. I see blowsion sells their own turf adhesive and they claim that its the "nastiest adhesive we could find". Any reviews on this stuff? I see weldwood referenced on this site frequently as well.
    charlotte,nc
    Re: what is the best adhesive for hydroturfing an old ski?
    everyone ive seen all use a product called weldwood red can by a company called "dap" any hardware store such as lowes home depot will stock it.
    Chicago / Portage, MI
    Yep Dap Woodweld. Basically it's a high strength rubber cement. I usually put two heavy coats on both surfaces, as some surfaces will soak in the dap decently. For a good bond, both sides need to be dry and tacky to the touch. If it doesn't feel tacky, put another coat on.
    2009 1100 SJ:
    Kawi 1100
    2009 SJ MINT:
    KP steering adaptor, Worx 228 intake [45.6mph gps]
    1987 WJ650:
    6M6, JD Intake Grate, 17/20, cheater pipe [42.4mph gps]
    1998 SXI PRO:
    3DR hull mods [TBD]
    Michigan
    Yep!
    PWCToday Newbie skidooseadoo's Avatar
    Jun 2016
    Ontario
    I use 3M Super 77 spray contact cement. Worked well so far.
    Mar 2011
    Brooklyn Center, MN
    weldwood only
    Feb 2002
    Vancouver, BC Canada
    Any brand contact cement.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    Frequent Poster AirJunky's Avatar
    Sep 2015
    Liberty Lake, WA
    Quote Originally Posted by skidooseadoo View Post
    3M makes a more permanent spray adhesive called Super 99 too. But it still doesn't compare to the Dap Weldwood stuff.
    Bill
    Current ride is an almost stock 94 550SX
    My JS550 build
    . - SOLD
    Jun 2016
    Ontario
    Good to know. Thanx
    Aug 2017
    Philly
    so no feedback on the blowsion adhesive?
