Results 11 to 20 of 46
    Aug 2011
    Austin, Texas, USA
    Re: 1998 1100 won't run in water
    Quote Originally Posted by Blairwill4 View Post
    Is there a way to test the coil/s without just throwing new ones at it?
    You can do resistance tests on the coils using an ohmmeter. If it's out of spec from that test then you probably have a bad coil. If it's in spec then you might have a good coil. Directions can be found in the service manual.
    Riding mostly Lake Austin
    PWCToday Regular spedesdamit87's Avatar
    Aug 2017
    US
    Quote Originally Posted by slag View Post
    I don't know of a way to test the spark reliably as it worked at idle, but broke down under throttle. I'm sure there are probably tests you can do with a multimeter, but I don't know them. Ideally, you could "rent" an 1100 ebox from someone for a week or so and then return it but aside from that, I don't know. I had done the same things you did though, bypass the water temp sensor, thought maybe it had a low oil/fuel limp mode so I bypassed those also, even checked my crank indexing to see if it had shifted. In the end, it was electrical.
    If you don't have your velocity stacks on there right with the little rubber notch in the center of the vent in the top of the carb it would make everything happen that's happening to you it's what I did before I realize this
    Sent from my Pixel XL using Tapatalk
    Jun 2013
    Fort Wayne Indiana
    So you're saying the rubber boots with the long needles in them have a correct up and down side?
    Frequent Poster a1cnc's Avatar
    Jun 2017
    NH
    He is saying the inlet boots on the air inlet plate with the antiflash screen.
    1998 ZXI 1100 Red
    1994 Polaris SL750 $50 I couldn't help myself!
    I suffer from JOCD!
    Jet-ski Obsessive compulsive disorder
    Jun 2013
    Fort Wayne Indiana
    I don't think I'm understanding....
    Aug 2017
    US
    You know when you take the square box off the top of your carburetor covers you got those rubber tubes that come off your carbs at the base of them there's a little hole that's Square that if the rubber boot isn't centered in it blocks off all the air going to them those little holes make sure that the little rubber block is dead center of that hole
    Aug 2017
    US
    Quote Originally Posted by spedesdamit87 View Post
    Guess I'm not the best at explaining sorry
    Jun 2013
    Fort Wayne Indiana
    Okay I'll check it tonight. That makes a little more sense. I'm sure I'll understand once I see it
    Jun 2013
    Fort Wayne Indiana
    So two of the tubes were perfectly line up. The center turn was just slightly offset. like about 10 degress offset or less. Does that make that much of a difference?
    Aug 2017
    US
    It did mine
