Results 1 to 9 of 9
    Top Dog bandit88's Avatar
    Green Bay WI
    Help selecting a Advent timing curve
    So I need help selecting a Advent timing curve. I have curveset D7 which includes SXI 22,21,10 and 14. This is on my JS conversion with a PJS Viper 9000 cylinder on a 650 bottom, 800cc. Motor has dual 44s, factory xir pipe (wet), ECWI, and a TBM total loss flywheel. Have been running VP110 in it. I have been using SXI-10 since that is the safest curve but I feel like I should be able to bump it up, but am not sure what would be safe. Motor specs from Newmiller are pictured. Since it is already setup for 110 do I want pump gas curves as anything more will bump it further and require greater than 110, or am I just safe to run pretty much anything at this point? Need some schooling here.
    -95 750SXI
    -90 TS650
    -91 300SX
    Top Dog
    Oct 2006
    under a ton of work
    Re: Help selecting a Advent timing curve
    your cranking psi is 187 and you're running 110 octane?
    Green Bay WI
    -95 750SXI
    -90 TS650
    -91 300SX
    Green Bay WI
    So this is what Chris told me for this motor:
    -10-15 static for easy starting
    -28-30 by 1500 for low hit
    -start retarding by 5000
    -18-19 at max RPM with 110.
    With that said, it looks like I could use a little more aggressive curve, but I will be going with SXI-22
    -95 750SXI
    -90 TS650
    -91 300SX
    Sin City USA
    SXi21 is the better and safer curve.
    Green Bay WI
    Hey! you're back!
    What is better about 21 over 22? They look mostly the same except 22 holds more advance at peak RPM, still well below the safe numbers Newmiller gave me for this motor and fuel. Am I missing something?
    -95 750SXI
    -90 TS650
    -91 300SX
    Apr 2006
    Oregon
    Looks like the Advent website is no longer... Does anybody have a link to the Advent timing curves? Short of that, how about the individual D7 curve set timing specs??
    Home of Newmiller Machine
    Green Bay WI
    Here you go Chris: http://www.adventignitions.com/timin...2.php?engine=1
    -95 750SXI
    -90 TS650
    -91 300SX
    Apr 2006
    Oregon
    That is what I was looking for... For whatever reason my old link wasn't working and it didn't come with a google search.
    You could pick any one of the curves in D7 and be totally safe with non O2 110 octane. You could try SXI-22 and if the upper midrange and max rpm feel lazy contact Advent and have your
    unit re-programmed with something including SXR-26 and SXI-19 for 110 octane and maybe SXI-21 or SXI-22 if you ever decide to go back to pump gas.
