What causes low cmpression
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Sep 2008
    The flakka capitol of Florida
    Taking apart a 185 motor from an 03 gtx, it has 150/100/50 psi front to back. Cylinders and pistons are visually perfect. Head/valves are as well, and there's no light visible through the valves. Haven't had a chance to do any other tests yet.
    Is there a common cause for this? Anything other tests I can run? These new fangled engines are a pita....There's a never ending supply of oil constantly leaking out everywhere.
    Re: What causes low cmpression
    On a 185 i would suspect a head gasket. Was there no coolant in the oil?
    Top Dog Benflynn's Avatar
    Aug 2015
    Birmingham
    Time for a leak down test, get a plug adapter, fill that ****er up with air and see where it going
    Aug 2015
    Birmingham
    Unless it's diss assembled, I'd be looking at cams and bent valves, if it was the gasket u would be able to see it if u look really careful at the marks left on block and cyl head, at least if it was passing water
    Sep 2008
    No oil in the water, no water in the oil.
    It's disassembled unfortunately.
    Ill check again for signs of a head gask leak, but ive looked a coupk e times already and s aw nothing.
    REALLY hoped id find some gummef up rings, but no go.
    Sep 2008
    It's definitely the valves leaking. Any recommendations on where to send the head to get rebuilt?
    How are the seats and guides? Usually they are good. I disassemble and clean everything then lap the valves back in and install new seals....done!
    Aug 2015
    Birmingham
    I pour acetone or even carb cleaner in combustion chamber and ot will leak through bad valves
    Aug 2015
    Birmingham
    I pay 8$ a valve at local ms, but u might have a problem with some having small enough stones or what ever
    Sep 2008
    Thats exactly what i did but with diesel fuel.
    Not sure on thr cond. of the guides and seats yet.
    Thanks everyone for the help so far
