Results 1 to 6 of 6
Thread: A few questions
    PWCToday Regular Tone's Avatar
    May 2017
    Copperas Cove, TX
    A few questions
    I started going through my new to me 91 SJ and came up with a few questions. I apologize if these are stupid questions but the stand up world is new to me.
    First, I found a couple of rubber pieces laying in the hull, I went through some parts breakdowns and I couldn't find them. Can someone identify them and tell me where they go. Or Just let me know if I don't need them.
    Second, how are you guys connecting your winch strap to your hull? I ran the strap through the bow eye hole to get it home but it looks like its damaging that rubber piece (might be fine once I get the bushing in). Plus I doubt that strap was designed to do that. Was thinking of getting some D-ring to put in there.
    Third, are these rubber tubes on the hood important? One is broken off completely while the other is permanently bent. I don't think any air will be getting through it.
    I'm just trying to get it in the water so I can play on it for the remainder of the season. Over the winter I plan on cleaning it up, getting it painted, adding footwells and replacing the hydroturf. I want to learn to ride it before I start changing everything out.
    Jun 2017
    CA, USA
    Re: A few questions
    The only one I can really answer is the last one. You'll want those tubes to be below your engine/intake area. If water comes in you don't want it dumping on top... It needs to go straight to the bottom of the hull.
    Take a measurement and pick up some new tubing.
    May 2017
    Copperas Cove, TX
    Re: A few questions
    Thanks, Ill pick up some new tubing this week. I found an answer to the rubber piece, it's a support for the fuel tank.
    I still need to find a better way to attach that winch strap.
    Top Dog
    Oct 2006
    under a ton of work
    Re: A few questions
    bow bushing is all you need.
    Re: A few questions
    To answer your questions;
    1st - That rubber is originally glued to the hull floor (Bottom) Right behind the fuel tank. Helps keep the tank from wanting to slide backwards towards the engine. The fuel vent tube goes in the holder.
    2nd - For stand ups / and other skis with a bow eye, proper trailer set up is a straight upright post, with a "C" Bow stop and pin like this;
    https://www.watcon.com/trailers-beac...ailer-bow-stop
    As stated above, a bow eye bushing is also a good idea;
    https://www.watcon.com/body-hull/nose-bushings
    3rd - Yes, you need your hood down tubes. You can probably find a used one here by placing a wanted to buy ad.
    email watcon@watcon.com
    Please visit our web sites
    May 2017
    Copperas Cove, TX
    Re: A few questions
    Yeah I glued that rubber piece down last night.
    As far as the trailer goes I'm still trying to decide what I am going to do there. My trailer is only a 2 place, I had to put one on a stand to get it home. I think with the bow eye I should be good hauling it short distances with this set up. I may get rid of one of my sit downs or find a way to haul my stand up in my truck.
    I'm going to check hardware stores for tubes that will work this evening. I've seen replacement kits online I might try once this turns into my winter project but for now I shall ride.
    Again thanks for the helpful responses.
