Results 1 to 10 of 10
    PWCToday Regular jscase's Avatar
    Oct 2015
    Williamsburg, VA
    Bow pole for standup trailer
    I'm repurposing a trailer for my 650SX. I'm looking for a straight vertical bow post (winch post). Specifically one with holes in it to mount the bow stop. All of the ones I've seen online are tilted at varying degrees and without mounting holes. I'm looking for a straight up and down (90 degrees) pole. Thanks - Jim
    '87 Kawasaki 650SX
    '01 Waverunner XLT 1200
    '03 Waverunner XLT 800
    Top Dog Benflynn's Avatar
    Aug 2015
    Birmingham
    Re: Bow pole for standup trailer
    2" square tube is what pwc bow stops online clamp to
    Oct 2015
    Williamsburg, VA
    But where can I get one?
    '87 Kawasaki 650SX
    Aug 2015
    Birmingham
    I get 90% of everything off eBay, or get a piece of tube, a square piece of plate and 2 square u bolts, add a friend with welder.
    Aug 2015
    Kalamazoo, Michigan
    I get all of my raw steel material from Alro Metals Plus http://www.alro.com/metalsoutlet/ you can also try www.McMaster.com
    Aug 2011
    Austin, Texas, USA
    And if you don't have a friend with a welder that's where something simple like this gets expensive.
    Riding mostly Lake Austin
    Cypress, TX
    Cypress, TX
    Aug 2011
    Austin, Texas, USA
    I definitely wouldn't chide the OP about this. I have looked for one of these in the past and absolutely could not find one. Of course now that I don't need one you come up with this.
    edit: 3" tubing is pretty big for a standup
    Cypress, TX
    In the past, I've made uprights by using 1-1/2" x 16" threaded galvanized pipe nipples with corresponding 4- bolt hole flanges plus square u-bolts for trailer attachment and round u-bolts for the poly vertical bow pin stop.
    Available at Home Depot, Lowes or Ace hardware. They can cut and thread galvanized pipe to your spec for free.
