Results 11 to 15 of 15
    PWCToday Guru E350's Avatar
    Jul 2015
    Sacramento Delta, CA
    Re: '88 x2 650cc What's the size of the oem Exhaust Manifold Bolts?
    still standin: Holy cow! That is just the opposite that I was thinking. I just emailed Rad Dudes at:
    RadDudesFreestyle@gmail.com
    Thank you.
    Learning Slowly...
    Jul 2015
    Still standin and bandit88 are correct, the proper bolt is a 10mm 1.25 pitch and for the 1986-1988 exhaust maniforld with the closed-end (i.e., blind) bolt holes you better be spot on with your length estimate, otherwise you are going to strip them when they hit bottom of the hole and you keep tightening.
    The Rad Dudes guy has the proper bolts in socket head stainless and he is is very, very, very helpful:
    http://www.raddudesfi.com/raddudesfi.com/Welcome.html
    For my application he suggested that I go with a stainless steel hex cap bolts from ARP-bolts.com because they come in shorter lengths with a hex cap which will work better under the pisser port on the particular stainless steel exhaust pipe we have.
    I ordered a 1989 and up style 650cc exhaust manifold and will order the proper bolts for it and will install it when and if I pull the engine to do crank seals.
    In the interim, I am going to run a 10mm 1.50 tap down the three pipe to head bolt holes on the existing partially stripped 1988 style exhaust manifold and just use hardened 10mm 1.50 pitch bolts.
    I am pretty impressed with most of the work on this ski, but this two of the three bolts are the incorrect 1.5 pitch and one is the correct but stripped 1.25 pitch was bs work done by a prior owner. All he needed to do was to cut short the oem bolts when he put the shorter shoulder stainless steel after market pipe on, and everything would've been good...
    Learning Slowly...
    Top Dog bandit88's Avatar
    Green Bay WI
    Yep, M10, my bad.
    -95 750SXI
    -90 TS650
    -91 300SX
    PWCToday.com Is My Home Away From Home x2jess's Avatar
    socal
    https://www.rhaasproducts.com/Produc...ctCode=HPBOLTS
    RHAAS can supply you with the correct hardware as well
    Special thanks to Newmiller Machine, IPD Graphics, Psycho Sims Racing, C57 Racing Products, RHAAS Products, and IMPROS!
